the_fablab_
- Apr 15, 2022
Center mounting your truck isn't that much more work huh?I hear you Mikey, you're just kind of boring. I agree moving the motor back would be more work than not but really not much more work beyond that. Not sure where you've been but the whole front is cut off already. Fitting a radiator up front would be the biggest challenge.
Kelly is a bad influence I could get onboard with, lol. Have you seen @laramie_nielsen on IG building up a Hummer?
How long were the upper arms on the old setup? Why not just build some frame rails back and build some slightly longer upper arms, and an upright, lower arm and swing steering to go with it? That way you can run your old cooling setup, etc.? You should be able to get 20+ inches of wheel travel and use the shocks you already have no?
