Ford 9" SF Housing, Where to buy?
SHOP WERX
Im poor and in need a new rear end housing. Specifically a ford 9" semi float fabricated housing. Im really not wanting to spend over $800. I also need one with the bearing flanges already welded on. There is a ton of options from companies whose main focus is street cars. But they dont have thick enough axle tubes. Any companies i should look into?
The junkyard 9" housing that I beefed up for my bronco is officially done for. One axle tube is bent more than i can probably fix. Aswell as the mounting surface for the center section is about as flat as a microwaved piece of bacon, and cracked out quarter of the way around. The center section and axles are still holding strong. So I would like to swap the guts into a better housing for the time being. I really dont want to spend the money on a FF at the moment. So if you know of a good affordable housing let me know! I would prefer it to have a 3/8" faceplate and 1/4" wall 3.25 tubes minimum. In the long term, if I have a good housing, i can always cut the ends off and do a FF conversion, and add 10" ring gear when I have the time and money. Thanks!
Pictures from when trussed and tabbed the rear end.
My ranger had a Shreiner full floater rear end in it when i first bought the truck. It had some 35 spline inner “jumbo” 26 spline outer axles (i guess that’s common with dirt track/oval roundy car stuff) Their rear ends and hubs are very affordable and zero issues with it.
Hadn't heard of them before. Will definitely consider them if/when i need to do a FF conversion. Damn good price on spindle, hub,and seal kits. But for now im just looking for a decent SF housing.
That seems to be pretty beef have pics of the damage
But it wasnt beefy enough! I didnt take pictures. Its hard to show and do it justice in a picture the issues. What should be a machined flat "face plate" surface having 1/8 -3/16" high and low spots, and the surface being bent/cocked, hair line crack a quarter to third around the mounting surface, from getting bent/cocked. An axle tube thats bent 2.5* or so....
Doesn't come across on camera how bad it actually is
$800 WITH ends welded on? I think youre going to have a hard time finding that one...
Ruffstuff might have a black friday deal?
Baker Fab?
Not sure if any of the rock donkey companies make an affordable housing... (like rock assault)?
Baker Fab?
I dont think ruff stuff even offers welding on the ends. $800 is definitely pushing it. But i dont know if some lesser know company out there offers what i want. I know all the "offroad" offerings are outside my price range. And they're all built with Full floating in mind.
Quick Performance does ends welded at the factory but I'm certain its over 800. I think it was 1100 when I looked.
Quick performance housing is $1,350 once its all said and done. Its still only a 3" x .25" axle tube. I think im going to go with a Rhode Race Cars fabricated 9". $1300 chromoly center section with 3.5" axle tubes. If i need to go FF in the future, it will be a good candidate to receive the Shreiner FF conversion kit.
I ordered a housing from wicked creations Inc. $1050 shipped to Montana. I had never heard of them, but the algorithm saw me diligently searching for housings. So my Instagram feed was rampant with black friday deals and axles. It served up a reel of their housing to me. Idk if they'll be willing to weld a semi float housing end on for me. But i figure with it being designed only for a FF application the axle tubes must be damn straight and true. I can probably figure out a way to accuratly weld the ends on without buying/building an alignment bar and bushings. I might turn out a simple alignment bushing on a lathe tho. l'll post pictures when it gets here and comes together.
