Fab shop recommendations / list
Doubleggregg
Piggybacking on the post below about fab shop recommendations.
I have been around a little while, i do have friends in the industry but like everything its sometimes easier to not mix business with friends or just that friends shops are always slammed (for a good reason).
I am looking for a recommendation on a fab shop preferable north county / IE. Well rounded, trusted could be a side gig guy who does it out of his garage shop or an established shop.
leaf spring set up, roll cage fabrication, fuel cell cradle, seat mounting, type place. i dont have a tight time table, i do have a budget though so if it took a few months to get the job done i am fine with that too. Also, i was thinking about taking a week off work to help do all the initial bitch work / demo work.
Gregg
I'm totally blanking on his ig name, but there's a guy that was on DR and does work out of his front yard in National City I think? He had a white ranger he was building, and then a 2000s f150 but he sold that too. Let me think and find his ig
Edit: @Dzrt_ranger on instagram.
Gregg
think we can get a 2 for 1 deal? lol
You just have to have a wide enough axle to get the spring onto the side of the frame. You need at least 7 inches on each side in between the tire bulge and the frame.
The front mount sets the wheelbase, but I start with moving it 1.5” forward from the bump stop because the arc of the spring will flatten out and push the axle back through the travel and then I just preload the rear frame mount back once majority of the parts are marked up.
I have a 7" wider 9" axle housing that i am going to be using. to match my front which is 3.5" per side wider so my front end is also 7" wider than stock
You’ll need 7 inches on each side, which is 14 inches total. Put wheels on the 9 inch you have and measure in between each tire then subtract your frame width to the outside then divide by 2 and see what number you come up with?
Can you run the 64" springs off mounts under the frame like toyota leafs or do they need an inverse shackle to work correctly?
You cannot run it under the frame unless you add an extra thousand pounds of weight to smash the spring down to a proper ride height.
I do have a different front pivot that puts the spring underneath the frame and still has the shackle on the backside running upward for this much arc, this way you can run a narrower Axle.
Copy not parallel frame rail crap.
Remove factory frame, replace with box tubing off inside to mounts leafs off of and not need a super wide rear axle. Not cheap to pay a fab shop to do it but easiest way to run them with the parts you already have.
