84projectFORD
- Apr 1, 2022
Alright, so first off, I know this is not going to be an apples to apples comparison because my front end is not 100% cross over to a bronco and I’ll explain why but first the issue.
So the grand tracker is up and running. First test drive a month back showed toe way the fuck out and she was all over the pavement but had an interesting issue. Turn right, turns like normal. Turn left and front end jacks up and rf tire scrubs hard. Slight turn or multiple cranks into the wheel, doesn’t matter.
Couple weeks later, go off road testing and does well in the dirt. Ride height was too high so dropped it down an inch. Also moved the tracker in and out of the shop multiple times to get the toe set at 0 or 1/16 in at ride height. Did not fix my pavement issue but helped with is driving straight. In dirt you don’t notice it at much but turning left you can see the rf pushing dirt yet turning right it does not.
Now what is done. Steering is the “ambulance” upgraded steering and I had to put a bend in the pass side tie rod to clear my shock mount. Not a ton, I think 5-8*. Pitman arm is stock, steering box is stock, beam mounts are stock but has uniball pivots. Radius arms are 36” long from back of beam to pivot. I have 12* of caster in the thing and did 5/8” c&t on the beams to get camber flat at ride height. Im guessing I’m 2-3” higher than stock. The frame is also not flat, it is raked up 8* if you measure where the stock spring mounts go. Figured it help keep faster from going negative at droop and it lowered my ride height.
That said, something is not right. I get it’s not going to be a handling machine on the road but it shouldn’t be doing what it is. Maybe some under hard turning. I noticed desolate and solo sell drop pitman arms with their kits. Wonder if that’s something I need to look into? With the raked frame, it moves the pitman arm up higher in relation to where the radius arm pivot and beam pivot imaginary line would go through to the pitman arm. It’s about 2.5” above that line (best guess as i just jumped under it to kinda look at this)
Thoughts? Bend in the tie rod screwing me? Pitman arm too high? I’d like to hold off on swing steering but shit, I may have to do it sooner than later if that’s the fix
