CBR oil cooler fitting
exp24
Looking to plumb the oil cooler and need a double male for the inlet and outlet. Diagram shows AN -10, does anyone know what the female thread is?
The thread on the cooler for ORB-10 is 7/8-14, same as a -10 37 degree AN or JIC fitting.
These are the fittings you want:
https://www.discounthydraulichose.com/6801-jic-37-x-straight-thread-orb-90.htmlhttps://www.discounthydraulichose.com/6400-jic-37-x-straight-thread-orb.html
These fittings are steel and will never break.
Probably good to step down to 3/8 or 1/2 depending on the flow of your transmission cooling circuit.
I normally use hydraulic hoses for trans coolers as they are much tougher and cheaper than building AN lines. There is slightly more weight, but I feel that's ok on a prerunner / play truck. SAE 100R1AT Hydraulic Hose works good and is rated to 2250 psi.
