Anybody have tips for regearing?
Gotta keep in mind I fix machinery so I have random ass pullers and access to some that are up to 8ft long to remove propellers 30ft in diameter via guys I can rent from. I’ve pulled pullies from 1”-34” in diameter with little to no heat. I made a press on sleeve for your pinion bearing from tubing and a bung I machined. If you want to meet up and hand the the pinion shaft I can return it with old bearing removed and new one installed as needed. Just keep me posted.
Alright I tried and I threw in the towel anyone know a shop or someone that can handle the job I have all parts so just the labor I have both axle and diff out so it’s easier already got quoted 1200 but not until mid Jan
You could try Martin @ Mobile Gear. He was reasonably priced and quick turnaround a few years back. (310) 704-1635
  • Like
Reactions: RMC
That guy has messed up 3 setups at our shop 🤦🏻‍♂️
Did 2 on the same day, both had ring gear bolts fall out 🤦🏻‍♂️🤦🏻‍♂️
Seriously? Well that sucks to hear. Going on 3 years and few thousand off-road miles on mine with no problems so far. Thanks for the heads up!
I’m sure he has plenty of successful ones but 2 for 2 failing from ring gear bolts we quit using him. That was 6-7yrs ago then finally used him again a month ago and immediately on driving the pinion seal was puking
310 is suspect. It’s sad because LA had so many good shops 30-40 years ago compared to now. Looking for a shop to rebuild my cylinder head this summer I went to 2-3 shops with great reviews that are still up on Google but which were obviously permanently closed when I went there.
