Been waiting on Paint for the bumper. It had shown up yesterday but probably going to hold off on painting it until the weekend so I can try and prep the bumper to the best of my ability...
I already spoke with Mikey but what's the best way to prep/paint over powder coat?
Anyways -
I started a new little project for
@marcytech OBS Ford Ranger 3rd Light Mount grown and fitted to a OBS Ford Bronco and then use factory wiring and then try to make it all work well for my intended application.
So I will start off by saying this is probably one of the most expensive things I've worked on that provides very little value to what this Bronco's intentions were... $200ish mount, 3
@Baja Designs S2 lights, replacement stainless hardware, 2 dimmer switches and wiring junk.
Long story short if you were to try and replicate this with the same products it's like $800 for a stupid light... That I love. aka Priceless.
Wow that was long winded. Back to the project.
- Baja Designs lights typically ground on themselves (found this out by testing and verified it with @Baja Designs)
- To make said dimmer switches work they can not be ground together.
- @marcytech bracket is aluminum and therefore has continuity.
- Fix - isolate where they were ground through.
- The 4 stainless bolts and the Cutless designs Mount
- Fix - Put rubber between metal and bolt.
So I tried just using the goofy rubber metal washer thing. It was still grounding out on the through hold of where the threads went.
I then added longer bolts and some shrink wrap. Then I needed to open the through holes slightly larger on the Cutless designs mount to allow for the added girth
Not as pretty or clean but for right now it all works.
Ideally I'd find the time and material to make a plastic insert that goes into the light Mount.
I'm Terrible at reading wiring and always over think or think about it wrong.
lets just say it took me a min to figure this out because most dimmer switch wiring online only has 3 wires, not 4 which just through me off.
