1973 F250 Prerunner Project
2012SVTSC
CA
Hey!
I am starting another project, I know, I've been struggling to work on my other project but hey here I am!
Anyway this time I have help from my friend, who is an excellent fabricator and our goal is to build a non-competive race legal class 8 truck (1400ish now) that doubles as a fun prerunner and street legal in CA.
Well anyway this is day one.
We got hooked up with a truck that once had a camper on it but got stolen by some tweekers some time around 2000 or something. Anyway it was recovered but the camper was trashed so it was removed.
Apparently they stole the mirrors, radio and sunvisors.
Afterwards the owner parked it in the garage and it has been sitting for about 20 years... until today when we pulled it out and brought it to lake E to get beamed, linked and caged!
So I'll be posting update here to my favorite fourm!
Here are the pictures, wish us luck :
Old resting place:
towed home:
no smoking
20251115_151620.webp20251115_151608.webp20251115_151629.webp20251115_162334.webp20251115_162350.webp20251115_162546.webp20251115_162904.webp
I hope you find 3 more Super Swampers
Haha well I got the truck from an awesome old lady and her late husband had about 6 tires and wheels that I took to get rid of for her that one included plus the old bed frames that where keeping the truck from floating away. Basically filled the bed of the diesel with a dump run.
Small progress bits,
Tested out the wheels, going with some stylish beadgrips from method. Guess we won't be cool. Oh well. 20251207_111938.webp
Removed the beams, My Friend preped the radius arms mounts and tacked them for now. He said he may make an account here.
This is just a picture of all the diy front beam plates.
And of course some fun AI renders
Those wheels will look nice 🤘🏼
Also what’s up with all the white dots in the cab? Is that for the scan process or did I rub my eyes to hard waking up?
Thanks I actually really like the wheels, especially with the 8 lug. The dots help align multiple scans together and maintain scale and orientation, at least as far as I understand... Im not actually proficient with the use of the scanner. I am being helped.
badass. that steering wheel is a solid come-up! assuming it's original ford that thing is worth big $
Unfortunately some tweaker has the OG wheel from when the truck was stolen. But maybe this is a ford replacement idk 🤷‍♂️
So since DIY-Offroad seemed to design the beam kit with the idea that the beam ends are boxed out instead of an I beam shape. My build master went ahead and started getting the beam ends in order so the the diy kit will fit up properly.
DiY off road beam cad, you can see its a solid box not an I beam shape.
So to mate the plate work properly here is what my friend did:
How I brought it to him lol
Clean up and box 📦:Screenshot_20251221_120058_Gallery.webpScreenshot_20251221_120114_Gallery.webpScreenshot_20251221_120131_Gallery.webpScreenshot_20251221_120302_Gallery.webp
Lets check in on this haha
The front beams are all tacked together, we need to install them and cycle then we can weld them up.
Vs : desolate radius arm
Vs : 44hd ttb
One thing that is slowing us down is that, it totally sucks having the truck on jack stands... so we are in the process of building some prep carts/truck mover.
One of two is basically done!
We are using 18000# house jacks 🏠
Frame sandwich plates
I just noticed... but how come the center ribs in your breams are oriented parallel to the ground instead of vertically? Seems like you've got them going the weak way for the direction I'd expect most of the load.
The factory old school I-beams are shaped like an I for a reason
I couldn't say on the design, we are following the plans from DIY offroad. I will say there are several vertical overlays on the front and rear that have not been added yet, so they will be quite a bit more robust than what is show at this stage.
just cause the plans are available doesn't make them good. But you also don't have to trust anyone else's opinions (mine included).
So I'm just saying that the internal reinforcing structures are oriented 90 degrees from the direction where I'd want them to resist the bending loads. They definitely look like it was designed to be easier to fab but not strongest possible. Consider the shape of the OEM beam & notice how yours is basically turned 90 degrees from that.
in any case - if you're happy with them, comfortable with the design & willing to accept the risk then party right on. (y)
I understand your logic. And don't disagree that for a vertical load having the inner ribs... vertically would be ideal. But, I do have confidence in them and the classic TeKK guys. Im more concerned about the tiny little wheel bearings this thing has and wee little brakes. But like pops always told me; "If you ain't living on the edge, you're taking up too much room".
Marketing that inspired me to build the beams:
And finally got the rest of the damn rivets out and the factory beam stuff free from the frame.
