‘78 ford f150 2nd lift with beams?
95_Bluwhale
Is it possible to lift my beam f150 these are the cast beams no idea about them like my ttb beams but want to hear some options for lifting the truck but not spending the 3k at autofab (too much for my budget) need something for looks not a prerunner just to run 33-35” tires and be a good daily for the fam?
This is what I’m going for.
I didn’t see drop brackets only offset ones to fix the wheel being pulled in with the bent beams I’ll check again I’m not a big fan of reading😂
Those were not cast, they are forged up to 1985, and you can heat them up and bend them to get more left. Make sure you cut the bottom of the radius arm to get the caster back plus add a little more.
Shows what I know about them😂I’ve been trying to get as much info as I can it seems easier than extending my bronco beams so far
