Small & Light Sammy
Lake EZ
A few people have asked if I have a build thread on my junk, and since I’m giving it a facelift now, I figured I’d throw one together.
I don’t have a whole lot of pictures of the stuff previously done, so might be a little boring, but maybe it’ll be helpful to others building a Sammy or thinking about it.
I’ve built a few different rigs in the past, mainly Yotas, and a few Suzukis. Even had a K5 blazer for a little bit.
At one time I had two rigs. A pretty well built 2nd gen 4runner on Chevy axles, and a little Sidekick on 33s that I got for $500 and didn’t care about. I feel like my 4runner was pretty nice, and capable. But I found myself having more fun in the sidekick, putting it places it shouldn’t be. But it was so small and nimble, it usually would make it through to my surprise.
That’s what made me want t build a Sammy and focus on keeping it little and light.
I know one tons and 40s are the norm for rock crawling, but there’s been multiple times I’ve been behind rigs on full width axles and 40s that get hung up on axles and diffs. Then the Sammy will walk right through.
My belief why, isn’t only it being small enough to fit “between” the rocks, but also having your tires closer together, leaves less of an area for rocks to catch your axle/diffs.
If that makes any sense. So, while the norm is to build rigs wider, I’m trying to keep this thing relatively narrow.
Now, I know this size rig won’t always help me. I’m obviously handicapped when it comes to water falls, steep climbs, or big cracks you need to straddle. But so far it seems to be a pretty good tool for the job. And has impressed me, many more times than it has let me down.
So here it is.
I picked up my 1988 Suzuki Samurai in 2022 from original owner in Arizona. He still had dealer paperwork!
That’s not to say it hadn’t seen the trails though. He had an off-road tuned carb, backyard made cage, 4.9 T-case with mount, SOA lift, rears up front, Lock-Right lockers F&R, chromoly front shafts, rear disc kit, and 33x13.50 TSLs on Allied Beadlocks.
Along with the Sammy, he gave me tons of spare parts. Axles, T-cases, Carburators…
I think he had disassemble like two other Sammys and just kept the good stuff.
One of the first things I did to it was replace the cage with the LowRange full cage kit, and added gusset tubes to it. Then electric assist steering from a Prius and LROR high steer kit.
Front axle ended up getting bent, so I built up some new axle housings with gussets front and rear, 4.57 R&P and replaced them, also putting chromos in the rear. I also installed front frame stiffeners during this time.
Ran it like this for a while, then swapped the T-case gears for 6.5s and installed LROR EOS Tcase mount.
The electric steering was great for mild wheeling, but running hard rock trails, I ended up breaking 2 or 3 steering boxes. So I pulled the trigger on a Hydro-assist setup consisting of TG crank/pump pulleys, TG steering pump mount, and TG hydraulic Ram. With this mount, you can run a 2005 Chevy corvette pump, which is pretty much identical to the TG pumps, but cheaper and lifetime warranty from the parts store. Also, the 6” ram was too much throw for the samurai’s geometry, so I had to take it apart and install, I think an inch of washers to reduce the travel.
I used a Sidekick box that I drilled and taped for hydro, and mounted with LROR “Wedge” style mount. Also an oversized reservoir/filter and cooler.
That’s pretty much the meat and potatoes of my rig, along with other little things like, HD tranny mount, seats, tire carrier, shocks, camo wrap, winch, lights, etc…
The little Sammy, does pretty good.
I do have Yota axles waiting to be installed, but I’ve been holding off till I’m ready to install them with linked suspension.
Till then, I’ve been able to beat the hell out of it on 33 inch tires without problems.
I did install a set of 35” boggers on it at one time, but broke a rear shaft on the first trail, so went back to 33’s. But that was before I had the rear chromoly shafts.
I currently have the Sammy apart right now. Mainly the body/interior so I can put a new wrap on it and change a few things on the cage and paint.
I’ll keep updates on that progress.
Alright,
Facelift on the samurai is underway.
If you saw in the thread for “Panamint Valley Days” run, I had put some old 35” BFGs on it that had left me stranded then parked for the weekend😢
So instead of throwing my old worn 33” TSLs back on, I decided to dish out for some new meats.
I’ve been seeing these Accelera Badak Extreme tires for a while, and have been curious. They are pretty much a knock of the Super Swamper Boggers. They were only offered in a 10.5” width, but finally came out with a 33x12.5R15, and went on sale for Black Friday, so decided to give them a try. I think I paid like $225 a tire.
They came in like 3 days from ordering.
Rubber compound feels close to swampers.
Haven’t mounted them yet, cause I plan on painting my wheels, which is going to be a headache.
I’ve read reviews on them talking about how well they do in mud, but we’ll see how they do in the rocks. I expect to see chunking, but hope it will be minimal cause my junk is pretty light.
Old camo wrap has been removed, it was all sun faded and a PITA to scrap off.
I removed seats, doors, tailgate, and windshield. Sprayed the floor, with rattle can bed liner. Cut and welded a couple things on the cage, then sand and painted the cage.
I’m just using, Rustoleum gloss white, but three of my cans where too old and wouldn’t stop clogging no matter how long I shook them.
So only got two coats on cage. Need more paint.
Here’s some photos, and a crappy Microsoft paint rendition of what the planned scheme is.
Always been a fan of Samurai’s! Here a pic of my good friends that we built up like 15 years ago
SJ410K pickup
Jeep tj long arm
Toyota 4x axles front and rear
Jeep YJ rear leafs
2.0 Fox Coilovers up front an 2.0 Resi in the rear
Rock sliders
8K winch up front in the bumper
Tube rear bumper
Baerd seats
Half doors
On 33’s
Fun little truck
SJ410K pickup
Jeep tj long arm
Jeep YJ rear leafs
Rock sliders
Tube rear bumper
Baerd seats
Half doors
On 33’s
Fun little truck
Nice! Looks like a good wheelbase on that thing also. Love the utility style bed on it. Reminds me of the Sammy they built on Dirt Every Day.🤙🏼
I love the Sammys! Here's my old one for east Coast crawling, but sold it when I met my wife, 2 seater for 4 people just didn't work, and didn't want to rework it all.
This picture is probably 2009. Was fun to wheel it!
I bet! That thing looks like a real good time to hammer on.
I’ve got 2 little girls that sometimes go with me. So I’ve gotta keep a back seat.
i will likely have to start thinking about a bigger rig once they start getting bigger😣
…or I can build another automatic 2door sidekick for them to drive…🤔😝
