No it’s the year before thatIs this the correct year Frontier?
Frontier / Xterra 2WD Long Travel Suspension
At 5” wider per side and 1” forward, this kit achieves 14” of wheel travel with the stock brake booster. With booster removed for race applications, 17” travel is possible. Can fit up to 2.5” coilover and 3.0” bypass with custom mounts (built by installer) this kit should be installed by a...btffabrication.com
If not there is a guy in Yucaipa that builds Nissan stuff, and coincidentally I think his name is Nate…
Does he build custom kit or has a kit for a 2000 frontierJimmy Baja can hook you up
Ok thanks I will message them tomorrowHit up @cjdracing on Instagram. Tell him the boys from clean-dezert referred you and he will hook you up. All he works on is frontiers pathfinders and titans. Nissan is his specialty.
