Looking for flex plate and torque converter for 4.0 sohc
Scott
Installing a c4 in my ranger , I am looking for an 8 bolt flex plate and torque converter .
2008 4.0 ford motor
i just had my converter serviced by dalenzie inc down in oceanside. give josh a call @ 760 672 8898 and see what he can build you.
All of this you ask for is super rare. I would call Advance Adapters and put a TH400 or 4L80 behind it. You'll never pull the transmission again! And if you do end up going V8 you'll already have the TH400 or 4L80.
If you do end up sourcing the C4 stuff...make sure you dial in the gate shifter with the detents in the transmission or you'll fry it real quick.
Message me if you have questions.
this is a class 7 type truck, i am keeping the 4.0 and have already been told to "just put a t400 in it"
the truck is build around small motor and transmisson i dont have the room for the bell housing or v8
and i have the gates for c-4 on my art carr shifter.
thanks
Ahh gotcha! Josh is cool; hopefully he finds what you need.
Found the converter and flex plate adapter
Now I need a bell housing , the one I got from Dana Sniff just cracked when tightened up the bolts . ( it looked to be in great shape when I got it ) but I just noticed the upper right boss cracked out when I was installing the dip stick.
Is there any bell housing out there? Jesus this never ends ….. ha
Repair the bellhousing and run it. If you can’t weld aluminum, find a local welder that does.
And what @Klever was saying about your shift detente is you might need to modify your gate plate on your shifter as the c4’s are very particular about shift lever location.
Also has Juan not been able to help you?
I’m gonna repair it , I am going to still be lokkkng for a culhane bell , and will patch and repair what I got untill I find one . And yes! Juan came through , I got his last flex plate conversation, and he sent me a new pcm with the tune I need .
Juan is just hard to get ahold of and I always throw a hissy when I get shit figured out .
I should have just did what everyone has said , and put a th400 in it and been donzo.
Not sure if your still looking for anything in the future but I just listed a 2002 sohc, turbo 400 adapter plate, flex plate, converter and headers outside frame rail to clear th400
i found what i was looking for , thanks for looking out tho,
Juan got me squared away ,and tried to sell me on the th400 stuff but between him and a couple otherers i found everything i needed.
you have some good stuff for sale , good luck!
