2021 Transition Spire Carbon XT build (Size XL)
Harry Johnson
Spreckels, Ca
Just in time for bike park season! Located in Monterey county. Might consider trades for an XL Levo depending on year and build. Specs below. $4,400, but willing to entertain reasonable offers.
XL 2022 Transition Spire XT build. Stock build with the following exceptions:
165mm Praxis Girder HD Carbon Cranks
Praxis M30-BSA THREADED 68/73mm Bottom bracket
Praxis 30T DM 3-Bolt MTN Wave Tech Chainring 3 mm Offset
Deity Deftrap Pedals
Maxxis Assegai 29x2.5 WT front tire
Maxxis Minion DHR 29x2.4 WT rear tire
Stock build info below:
Wheel Size
29"
Frame Material
Carbon Fiber
Frame Material Details Japanese Toray fiber front and rear triangles, EPS molding process; molded chainstay, seatstay, and down tube protection
Rear Travel
170mm
Rear Shock FOX FLOAT X2 Factory, 2-position damper, Kashima coating, trunnion mount, 205mm length x 65mm stroke
Fork FOX FLOAT 38 Factory, GRIP2 damper, Kashima coating, 44mm offset
Fork Travel 170mm
Head Tube Diameter Straight, 56mm
Headset FSA No.55R/57, ZS56 upper/lower
Handlebar ANVL Mandrel Alloy, 800mm width, 35mm clamp diameter
Rise: 20mm (SM), 30mm (MD-XL), 40mm (XXL)
Stem ANVL Swage, 40mm length, 35mm bar clamp
Grips ODI Elite Flow
Brakes Shimano Deore XT M8120, 4-piston calipers, Shimano RT86 203mm rotors
Brake Levers Shimano Deore XT M8120
Drivetrain
1x Shifters Shimano Deore XT M8100, 12-speed
Rear Derailleur Shimano Deore XT M8100, 12-speed
ISCG Tabs ISCG05
Chainguide OneUp upper slider with bashguard
Chain Shimano Deore XT M8100, 12-speed
Cassette Shimano Deore XT M8100, 12-speed, 10-51 tooth
Rims DT Swiss EX 1700 Spline 30
Hubs DT Swiss 350, 15mm x 110mm (Boost) front, 12mm x 148mm (Boost) rear with 36 tooth Ratchet SL freehub and MICRO SPLINE driver
Spokes DT Swiss Competition
Saddle ANVL Forge Cromo
Seatpost OneUp V2 dropper
Seatpost Diameter 31.6mm
Seatpost Clamp Single bolt, 37.0mm
Rear Dropout / Hub Dimensions 12mm x 148mm (Boost)
Max. Tire Size 29" x 2.6"
Bottle Cage Mounts One inside front triangle, plus accessory mounts under top tube
