gascapkevin
- May 9, 2023
Listing this for a coworker. If you're interested or have any questions, reach out and I can put you in touch with him. Located in Kingman, AZ.
$5,500 OBRO (Or Best Reasonable Offer)
The Beast:
The specs:
1993 Jeep Wrangler YJ - chassis has 53k miles with clean title in hand
-4.8 LS engine from BD Turnkey Engines with wiring harness and ECM
Have all the paperwork and carfax from the 2005 Chevy it was removed from, with videos of engine running
74k miles on the engine when pulled
-GM Muncie SM465 transmission with granny low
-Novak Adapters, new bellhousing, HD clutch, hydraulic master and slave cylinders
-Rebuilt NP231 with SYE and 23 spline input yoke
-OME leaf springs and shocks
-1/4" molded rock rails
-32"x11.5x15 BFG Mud Terrains
My coworker got it as a project from another coworker and then life happened and he never got the time to finish it up.
Engine and trans are mounted
It needs the wiring completed, and transfer case installed.
Will also need a fuel system(no tank), cooling system, exhaust, and driveshafts figured out.
Was recently the victim of some vandalism and will need a new passenger side headlight, tail light, and gauges
More pics:
Vandalism:
The Beast:
The specs:
More pics:
Vandalism:
