The Turbo Glue Factory: Boosted Colt Build
Got my mount for the noisy 12 volt supplies under the hood
COP's
injectors
fans
VVT solenoids
IAC solenoid
all filthy bastards on the oscilloscope
these are powered directly off the dirty alternator. the queen of filth!
Fuck me
1 the AN10 atf fill i welded on is exactly where it cant be. dead head right into the main frame tube (blue cap)
2 the ISS/OSS wire bulkhead is of course too far back and jams on the sheet metal! (white cable)
both easy fixs.... when the trans is on the bench
Got my C.U.N.T. module mount done and out of aluminum too. l almost did it out of steel until i remembered this is a hi-po car
there is a straddle design and a single 3/8" bolt welded and coming up through the bottom to hold tension on it. once i lay some carpet down this will just pop through and sandwich it all together
