01SilverSender
- Jun 3, 2022
While it might be a controversial topic for some you cannot argue the benefits of having solid reliable 12 volt power at your disposal. This is a solution that is perfect for any limited space/ Prerunner applications but great for just about anything. Putting it in the Packout keeps this setup rugged and sealed from the elements. The smart shunt makes it possible to view all the charge and output statuses from your phone. All components fit entirely inside of a Milwaukee Pack out which allows for endless and simple mounting applications. Several flush mount ports on the sides which include
-Solar charge input
-Vehicle charge input
-50 Amp 12v Output
-Tri USB A and C ports
Heres a quick spec sheet as well:
CHARGE CONTROLLER: REDARC BCDC1225
BATTERY: DAKOTA LITHIUM 100 AH
MONITORING: VICTRON SMART SHUNT
If anybody would like to know more about this setup or share your own be sure to reply!
Let me know if we can set you up with something like this!
-Solar charge input
-50 Amp 12v Output
