Extended brake lines
chaserm011
Anyone know a good place to find extended brake lines for a 98+ ford ranger. I had read somewhere that jeep extended lines would work. Anyone know if this is true or where I could find some for my truck?
I have also read that you can use f250 extended lines. Anyone know if that’d work?
It’s best to measure out what length you need when the suspension is dropped out with rope. Run the rope along areas where you can secure it to something with zip ties or whatnot so it’s not flappin near your tire then go to Kartek or a place that makes customs length hoses and get a braided steel line made in your measured length with the same fittings your current hose has.
Do you know what the fitting type is and those measurements so I know what to order from kartek?
