Big Performance in a Small Package: A Closer Look at the Baja Designs S1
Baja Designs
At Baja Designs, every light we create starts with one goal in mind, performance that’s proven in the most punishing conditions on earth: racing. Only after a product survives Baja do we bring it to you. The S1 is no exception.
This little light delivers serious output in a 2.1-inch housing, making it the most versatile compact LED we’ve ever engineered. Whether you’re building a chase rig, upgrading your UTV, or just need more light in tight spaces—the S1 is your go-to.
Take an inside look at what makes the S1 the most versatile and powerful compact light in our lineup—built by the Scientists of Lighting.
Race-Proven DNA in a Palm-Sized Package
At just 2.1 inches, the Baja Designs S1 puts out 2,320 lumens using a single high-output LED paired with ClearView® optics illuminating into lighting. Zones 1, 2, 4, and 51. That means you get performance normally reserved for larger lights—now in a form factor that fits anywhere. We took the DNA of our race-proven XL80, scaled it down to a single 20-watt LED and optic, and created a light that’s small enough to mount just about anywhere—but tough and bright enough to be used as a standalone driving light.
Built for Just About Anything
The ethos behind the S1? Small but powerful. You want a chase light? Done. A tight-fit driving light? No problem. Something to light up your camp or workspace? Easy. This light is one of the most adaptable stand-alone lights in your lighting setup, and we’ve built kits around the S1 for specific platforms and use cases:
S1 Universal
S1 Black LED Auxiliary Light Pod Pair
S1 Black Flush Mount Auxiliary Light
S1 White LED Auxiliary Light Pod Pair
S1 Headlight Kits for UTVs
The Baja Designs S1 Headlight Kits for UTVs such as the Can-Am Maverick R, Polaris RZR Pro R, and Kawasaki Teryx KRX1000 are plug-and-play replacements for the OEM headlights, delivering massive increases in usable light and off-road performance.
  • Maintains a clean, OEM-style look
  • Dramatically improved beam distance and width
  • Easy install, all hardware included
Whether you’re racing or just out exploring, these kits deliver real off-road visibility.
Can-Am Maverick R Triple S1 Headlight Kit
Polaris S1 Triple LED Headlight Kit
Kawasaki Teryx KRX S1 LED Headlight Kit
The S1 Trail Lens
We took the S1’s versatility even further by developing a dedicated Trail Lens, designed specifically for motorcycles, dirt bikes, and singletrack riding. It’s a targeted solution for riders who ride slower, more technical trails — giving you light exactly right where you need it – optimizing a light beam pattern with both vertical and horizontal light spread.
We developed the Trail Lens because we ride the same trails you do — and we know how frustrating it is when your light doesn’t hit where it should. Through testing, trail riding, and real-world rider feedback, we engineered a solution that gives you more usable light exactly where you need it.
S1 with Trail Lens LED Auxiliary Light
S1 Hitch Light Kit
Whether you’re reversing on the trail or lighting up camp, the S1 Hitch Light Kit turns your 2″ hitch receiver into a clean, functional rear light. It includes a secure mount and a plug-and-play harness, so you can install it in minutes.
  • Great for backup lighting
  • Trail-ready and rugged
  • It can be used as a chase light
  • Easily removable when not in use or towing
S1 Universal Hitch Light Kit
S1 Laser
Want even more distance? We integrated our laser technology into the S1 housing. It’s perfect for high-speed runs—or for lighting up somewhere deep in Zone 51.
S1 Black Laser Auxiliary Light Pod
S1 Black Laser Auxiliary Light Pod Pair -
Every S1 comes with options—thanks to our uService® lens interchange system and beam-specific optics. You can choose:
  1. Spot – long-distance focused beam
  2. Wide Cornering – ideal for trail and corner lighting
  3. Work/Scene – broad output for camp or area lighting
  4. Trail – designed specifically for motorcycles and singletrack riding with a vertical and horizontal light spread
Always Innovating
At Baja Designs, innovation always starts with a challenge—and ends with a solution that’s race-proven and adventure-ready. The S1 embodies that spirit. It may be small, but it’s built to perform in the harshest environments, from wide-open deserts to tight singletrack. With multiple configurations, beam patterns, and vehicle-specific kits, the S1 gives you the flexibility to light your way, no matter where the road, trail, or racecourse takes you. Like every Baja Designs product, it’s backed by our 30-Day Satisfaction Guarantee and Lifetime Limited Warranty.
Best,
Brahian Herrera | Forum Sales & Support
Email: brahianh@bajadesigns.com | Phone: (760) 560-2252 Ext 201
